even if it isn't leaking, the ABS light will still come on if the fluid is low. as your pads wear, fluid replaces the worn pad area and the level of fluid goes down.
fyi, there's no code(s) for an abs light. it's got nothing to do with the odbII stuff.
What?I pull abs codes all the time through the obdII connector..with my modis scanner....you really need to just get the codes pulled....and 120... is way to muchhhh!!!!!We charge 42.50 ......doenst include fixin it but gets you the code or codesand a flow chart on what could be the prob....
