Eh I quit...
Old 05-10-2007, 08:05 PM
Jonny.GT
Jonny.GT's Avatar
Default Eh I quit...
I can't figure out why the hell my ABS light is on...
Anyone know of anyway I can get the problem diagnosed by a shop without paying the dealership $120 just to look at my car?
Jonny.GT is offline
Old 05-10-2007, 08:09 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
Default RE: Eh I quit...
autozone/some autoparts stores will scan it for you for free
2002GTAUTOVERT is offline
Old 05-10-2007, 08:12 PM
yourmom6990
yourmom6990's Avatar
check your e-brake. might sound stupid, but some people do it. even if its pulled up just a little, it might cause it to go on. check you brake fluid, master cylinder, etc. might even be a bad sensor.
yourmom6990 is offline
Old 05-10-2007, 08:17 PM
Jonny.GT
Jonny.GT's Avatar
well i've posted about it a couple times but never really got any follow through replies... I think it might be a sensor but i'm not sure cause no one repied haha but i'll try typing the story out one more time...
It use to be that whenever I would go on a steep incline or whatever with my front passenger wheel the ABS light would come on, then I would turn the car off then back on and it'd be fine.
Well I recently snapped my rear swaybar and lifted the cars rear to pull it off...
Since then my ABS light has been on, and yes I know it has nothing to do with the swaybar but I was thinking the wieght on that front wheel caused the issue, sound like a sensor to you?
Jonny.GT is offline
Old 05-10-2007, 08:23 PM
timeformiller44
timeformiller44's Avatar
weight in a vechicle prob wont cause the ABS to go on....you have 4 wheel speed sensors that all have to read exactly the same...if one or more isnt then your light will come on,,, need a scan tool to tell you your ABS code
timeformiller44 is offline
Old 05-10-2007, 08:26 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
sounds like A BS light to me. [8D][8D][8D][8D][8D][8D][8D]
that one needed a ****load of smileys.
didja check your brake fluid?
redass02gt is offline
Jonny.GT
Jonny.GT's Avatar
Alright well I'ma check around for an autozone and see if I can get you guys that code... Be back later
Jonny.GT is offline
Old 05-10-2007, 09:07 PM
Jonny.GT
Jonny.GT's Avatar
bump...
aparently autozone doesn't do that for free where i live, and even if they did the guy said that they have nothing for an ABS light...
-sigh- dealership here i come...
Jonny.GT is offline
Old 05-10-2007, 09:27 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
ORIGINAL: redass02gt
Old 05-10-2007, 09:35 PM
impaled
impaled's Avatar
as dumb as it sounds, do check your brake fluid. i had that pop on on my other ford, filled it up and it went away. mine was leaking because i had aleaky cylinder which i figured out after i filled it two or three times. lol.
impaled is offline
Quick Reply: Eh I quit...
