Timing chain tensioner or what???
Old 05-29-2007, 04:56 PM
2000GTFOOL
2000GTFOOL's Avatar
Default Timing chain tensioner or what???
Ok I am at a point where I can either pull the engine in the Stang and replace it with a no miles OEm engine or just tear the front end down and replace the timing chain tensioner.. I think that is what the problem is. The car has a ticking/rattle while idling and driving, it got progressivley worse over the past few months. Now the car needs this fixed and I can either repalce the tensioner or do a total engine swap..
What do you guys think??? ANyone had experince with timing chain tensioners going bad? I love my car and just need it back road worthy. BTW 86k miles on the car.
2000GTFOOL is offline
Old 05-29-2007, 05:57 PM
racer02GTstang
racer02GTstang's Avatar
Default RE: Timing chain tensioner or what???
do u have the new motor already??
the tensioner is an easy fix. also look into getting new guides with a higher mileage car
racer02GTstang is offline
Old 05-29-2007, 08:36 PM
oxfordgt
oxfordgt's Avatar
You probably have spun bearings.
oxfordgt is offline
Old 05-29-2007, 08:43 PM
Nitti00GT
Nitti00GT's Avatar
ORIGINAL: racer02GTstang
Yeah just get new guides. The guides have plastic on them so that when the chain passes on them it doesn't make noise. When I put my motor back together the plastic fell off my passanger side guide and now I get a slight tick from the chain passing over it. I'd say just take the timing cover off and replace the guides.
Nitti00GT is offline
Old 05-29-2007, 09:16 PM
ackuric
ackuric's Avatar
guides/tensioners wear, when mine when (driver side) the guide was worn, tensioner failed, could only hear it from outside of the car...seemd to be 1 click every 1 crank
ackuric is offline
Old 05-29-2007, 09:18 PM
ackuric
ackuric's Avatar
oh yeh and the mechanic/neighbor i took it to didnt even use a mechanics ear and diagnosed it as failed tensioner/guide within 5seconds
ackuric is offline
Old 05-30-2007, 10:07 AM
SmallFeesh
SmallFeesh's Avatar
ORIGINAL: oxfordgt
A spun rod bearing would last a few days... or more like hours.... at best! NOT months!
Replace the tensioner.... and the chain while your in there.... and call it a day!
SmallFeesh is offline
Old 05-30-2007, 01:30 PM
gjscott
gjscott's Avatar
How fast is the tick, once every engine turn or more ?
Is the tick from the front top or bottom of the engine ?
If it's the top and it's a faster tick maybe it's your valve clearances.
gjscott is offline
Old 05-31-2007, 11:12 AM
2000GTFOOL
2000GTFOOL's Avatar
This was back in the winter... It does it all the time now... not just on decel.. or idle .. all the time for the most part. The car is still very strong as far as driveability..
http://www.youtube.com/watch?v=R0tBoYw_Pow
Old 05-31-2007, 11:15 AM
2000GTFOOL
2000GTFOOL's Avatar
Oh I also replaced the belt tensioner with a new one and it didn't help at all...
Quick Reply: Timing chain tensioner or what???
