Car wont stay running!!!!
took it out of the garage last night and it wouldnt idle finally it warmed up and it idled at 500-300 I had the battery disconnected but I have started it many times and haven't had this problem. Do you guys think of needs to learn idle again of something else... Thanks
RE: Car wont stay running!!!!
Just did my filter last night it only took about 30 minutes, the tool that you need slides over the fuel line and allows you to release the spring clamp and "unplug" the filter fomr the line. Other than getting gas in my eyes[:@] it was fine. Just a litle tugging and it will give.
Heres something that will help if you do decide to do it (found it on these forums):
http://www.mustanghowto.com/engine/F...l%20Filter.htm
When it was stalling out, did you try to give it gas to keep running? If you try that when its cold and give it some gas and it stays running you need to replace the IAC. I think there about $40-50. Very easy to install.
ORIGINAL: MustangMike8705
