Car is shaking, please help.
Several days ago I noticed that my car (2000 GT 5-speed) was shaking a lot more than usual while driving around. The faster I go the worse the shaking is. At first, I thought my wheels and tires weren't balanced correctly because Irecently replaced my rear tires. Well tonight I went and got them re-balancedand the car still shakes. And on top of that, to make things worse, my clutch is starting to wear really fast. It used to grab around mid-pedal, but now it's grabbing all the way at the top. Maybe the shaking has something to do with the clutch wearing, but I would think if that was the case the there wouldn't be shaking when the tranny is fully engaged. Does anyone know what this shaking could be?
RE: Car is shaking, please help.
Well, I've been searching thru and reading some other posts and saw that a warped flywheel might cause shaking like I described. The only thing is, the car doesn't shake when it's not moving whether I'm idling or reving in neutral.
Also, even when I'm going fast, if I slightlypush the throttle the shaking getsweaker at certain RPMs. It's almost like I can reduce the vibration by matching areverberation at some RPM. My only other guesses would be the tires I just bought are deffective, or something is wrong with the rear end. Any help would be greatly appreciated.
mine was shaking really bad when i would let off the gas just got tires put on myself blamed it on that then came to find out today that 2 of the four driveshaft bolts came out!!!!!!!just changed ram clutch also and shaking was caused by putting the throw out bearing in backwards.
if it's only shaking at speed, it may be your driveshaft. it's possible some debris on the road hit and bent your driveshaft (you would have felt it though), or maybe a bolt or two came loose. when you get up to speed, if your driveshaft is a even a little off-balance, then it can make the whole car shake like that. if you have a jack and some jackstands, get underneath and make sure all the driveshaft bolts are tight, and inspect the u-joints just to make sure nothing seems out of place. leave the rear of the car on jack stands (so the rear tires are well above the ground), start the car up and put it in 1st gear and just let it idle so that the driveshaft can spin. look underneath while it's running, and you should be able to tell if that's what's causing the problem. other than that just take it to a mechanic.
Mine does the same thing. it drives really smooth up until about 50 and then from 50 to 60 it shakes a little and then from 60 to 70 it shakes real bad and then from 70 to 120 it drives as smooth as can be. i though it could be bad alignment or out of blalance but that has been checked a few times by different places. i dont have the best tires in the world, could that cause it too?
