? about preperation for cams
Im thinking about getting some xe270s or vt stage 2 cams. I know and understand why you need to get stiffer valve springs for new cams but it also says that you should have steeper gears and a higher stall(i have an auto). Why is this and is it really necessary?
RE: ? about preperation for cams
The steeper gears and higher stall are recommended because the more agressive camshaft grinds like the stage2 etc loose quite a bit of power around idle to say 2000-3000 RPM. The steeper gears and stall are to get you into the powerband quicker where you can take advantage of the cams.
IMO you should definatly get gears and a stall before cams on an auto car anyway, the gears/stall are going to net you much better results than any cam swap.
ORIGINAL: racer02GTstang
you will need notched pistons for those comp cams but you dont for the vt cams.
+1 on the gears. Right after I put my VT stage 1s in, I took it for a test drive (it was still N/A at this point) and I felt the need for gears even with those. Your going to lose a fair amount of low end power, but it worth it for the high rpm power and that amazing sound.
ORIGINAL: Emanpimpster
junior04
09-28-2015 10:53 AM
