Anti-seize compound on tri-ax?
Old 03-16-2008, 05:23 PM
Burtonsnow157
Burtonsnow157's Avatar
Default Anti-seize compound on tri-ax?
The installation instructions for the triaxsay that youre supposed to put some anti-seize compound on the handle if you use an aluminum shift ****. but should you also use it on the bolts that hold the shifter onto the transmission? since the bolts are stainless steel, and the trans is made out of what looks to be aluminum?
Burtonsnow157 is offline
09-16-2015 07:53 PM
09-08-2015 11:50 AM
ccwebb
08-11-2015 06:47 PM
STANGSUSPENSION
05-27-2004 10:53 PM
MineralGreyGT02
13
08-02-2003 12:58 AM
Quick Reply: Anti-seize compound on tri-ax?
