Pinging under acceleration
Old 04-11-2005, 12:07 AM
The02GT
The02GT's Avatar
Default RE: Pinging under acceleration
If it is guarenteed to fully combust then why would u have pinging/knocking?? Cause it is self-igniteing in a different spot in the chamber, if you have ever looked at the gas 87 is a light brown color and 93 looks clear like water, why? cause it is a cleaner fuel, plus it burns better than 87, 93 burns a little longer in the combustion chamber than 87 thus creating a "bit" more power, and it gets rid of pinging
ORIGINAL: Acer2428
ORIGINAL: The02GT
I don't see how 93 would hurt your car in the long run, it is cleaner than 87 thats for sure, you would prob see more carbon deposits in the long run with 87 than 93, but try 89 or 91 if you have it in your area to see if it stops the pinging, i use 93 on the weekends and 89 during the week...
ORIGINAL: deesgt
But would that high of an octane in a N/A car hurt my engine in the longrun? (carbon deposits)
Bull shat. There's more stuff in a93 than there is in 87, plus 87 is gaurunteed to fully combust, making it much cleaner.
The02GT is offline
Old 04-11-2005, 12:15 AM
tonys462
tonys462's Avatar
93 oct will do nothing to your engine it burns alot cleaner than the 87. it will most likley take away the pinging too.
tonys462 is offline
Old 04-11-2005, 12:20 AM
dc_mann8
dc_mann8's Avatar
ORIGINAL: Quatrocky
check your tranny fluid, it might need changed or flushed.
[sm=wtf.gif]
dc_mann8 is offline
Old 04-11-2005, 01:00 AM
sandcracker21
sandcracker21's Avatar
this is a dumb as question.....but wat is WOT?
and what is pinging?
my bad guys....im stupid
sandcracker21 is offline
Old 04-11-2005, 01:08 AM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: sandcracker21
WOT=wide open throttle and pinging sounds like small rocks being shaken in a plastic container.
code3GT is offline
Old 04-11-2005, 01:19 AM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
man. tech is going downhill.
MikeHawke is offline
Old 04-11-2005, 09:26 AM
The02GT
The02GT's Avatar
Knocking and pinging result when the fuel/air mixture self-ignites somewhere else in the cylinder, away from the spark plug...sometimes due to low octane like 87
The02GT is offline
Old 04-11-2005, 12:37 PM
pichinco
pichinco's Avatar
Had the same problem with my '96. I replaced MAF sensor, plugs, wires, air filter, ran fuel injector cleaner multiple times, etc. Everything I did helped a little. It wasn't until I ran 93 octane the problem was finally resolved. I also ran 89 and it seemed to alleviate the problem...most of the time. I begin to suspect someone may have tweaked/replaced the chip to cause this, but I have never dug into it to find out.
Just a side note. As gas prices climbed I began to wonder why I was filling it with gas $0.20 higher than the recommended octane. So I went back to 87...and was reminded shortly thereafter.
The only downside I noted running 93 was "harder" starts. That is I had to crank for 1 or 2 seconds longer when cold.
pichinco is offline
Old 04-11-2005, 09:07 PM
deesgt
deesgt's Avatar
ORIGINAL: Quatrocky
[sm=WTFsgign.gif]
deesgt is offline
Old 04-11-2005, 09:10 PM
deesgt
deesgt's Avatar
Thanks for all the info. I got about a quarter tank of gas. This weekend I'll run it as close as I can to bein empty and fill up with a higher octane, probably 91
deesgt is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
69Volunteer
09-30-2015 10:39 AM
Offendant
09-23-2015 07:21 PM
09-08-2015 11:50 AM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: Pinging under acceleration
