DTC help
Old 03-20-2008, 02:39 PM
miniman342
miniman342's Avatar
Default DTC help
We bought a DTC scanner the other day because i have a check engine light that wont go off. it says i have 9 dtc codes.
P0443
P1451
P0135
P0141
P0155
P0161
P1409
P1131
P1151
I tried searching on both here and google and found nothing. Can anyone help me out? THanks!
miniman342 is offline
Old 03-20-2008, 08:50 PM
miniman342
miniman342's Avatar
Default RE: DTC help
anyone?
Old 03-20-2008, 09:16 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
I think all of those codes are related to your evap system and your O2's.
Did you recently install that x-pipe? Is it possible you don't have MIL's installed or the O2's were plugged back in wrong?
Does your car run alright? I would pull the battery cables for a couple minutes. Then run the car for a while and scan again and if the O2's come back up as a problem, make sure they weren't crossed up and if that doesn't help, replace.
Dan04COBRA is offline
Old 03-20-2008, 09:22 PM
miniman342
miniman342's Avatar
ORIGINAL: Dan04COBRA
I bought the car with the x-pipe already installed. So i have no idea if the O2 sensors are mixed up or if there are MILs there. I'll try taking the battery cables off tomorrow and checking that.
Thanks!
Old 03-20-2008, 09:31 PM
91smokedgt
91smokedgt's Avatar
hopefully this will help: p0443 and p1451 are evap codes, check you gas cap, hoses to your canister, purge etc.
p1409 is a egr code
p0135,p0141,p0151,p0161,p1141,p1151 are dealing with your fuel control, ie ho2's injectors and vacuum system. i got these from alldatapro.com so there pretty accurate.
91smokedgt is offline
Old 03-22-2008, 02:13 AM
miniman342
miniman342's Avatar
ORIGINAL: 91smokedgt
p1409 is a egr code
thanks man!
ZW99GT
02-20-2008 12:06 AM
idcoocheimonster
06-11-2007 10:47 PM
casperorr
05-13-2007 02:27 AM
arthur
05-06-2007 07:55 PM
OUZBnd
12-20-2005 09:07 PM
Quick Reply: DTC help
