99 cobra will not idle
Old 03-20-2008, 08:20 PM
99snake70
99snake70's Avatar
Default 99 cobra will not idle
my 99 cobra has an intermittin problem. It will not start or idle after sitting for some time. I have to feather the pedal to start or maintain idle. TPS is good. Where to go next?
99snake70 is offline
Old 03-20-2008, 09:34 PM
91smokedgt
91smokedgt's Avatar
Default RE: 99 cobra will not idle
how long does it sit for?
check the charge on your battery. also you IAC could be stuck or sticking
91smokedgt is offline
Old 03-20-2008, 10:03 PM
sickness
sickness's Avatar
+1 battery--- my car did some wierd sh$t when the battery took a dump..
sickness is offline
Old 03-20-2008, 10:31 PM
99snake70
99snake70's Avatar
The problem is more prevalent in the cold, I store the vehicle for winter. If the car sits long enough for the motor to get cold, the problem comes back. It goes away after the motor gets hot. After reviewing the forum on similar problems, I think the IAC is sticking. How do I locate the IAC? Thank you for the help!
Old 03-22-2008, 01:18 AM
99snake70
99snake70's Avatar
Replaced IAC and everything is running great! thanks so much.
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: 99 cobra will not idle
