Procharger questions
I have an '01 Mustang GT that has several mods done to it. I have recently been thinking of getting a Procharger system. Im not sure exactly how some of my mods may be effected by the installation of a Procharger kit, or if there is anything that doesnt come with the kit that I might need. Also there are things in the kit that I already have. The following is a list of the mods I have done that may be related to this in some way:
BBK CAI
Granetelli Motorsports MAF
Prof. Prod. 75mm TB
Prof. Prod. Upper Plenum
Prof. Prod. Typhoon Intake Manifold
Ford Racing 24lb/hr Injectors
MSD Coil Packs
Hooker Long Tubes
Flowmaster Dual-chamber 40-series
No Cats
2.5" exhaust
Ford GT40 255lph Fuel Pump
Diablo Predator Power Programmer
These are all the mods that I have done that I think would effect/be effected by the installation of a Procharger kit. If there is anything that I need to do or things that I should take strongly into consideration based on what I already have, I would appreciate it if somebody knowledgeable in this subject could help guide me in the right direction. If you wish to contact me directly, my email address is lyle.j.poss@us.army.mil
Thank you
BBK CAI
Prof. Prod. 75mm TB
MSD Coil Packs
Hooker Long Tubes
No Cats
2.5" exhaust
Thank you
RE: Procharger questions
The kit comes with its own CAI, 42 lbs injectors, a 255 lph fuel pump and a Diablo chip. Since you already have a fuel pump, you could buy the tuner kit and get the injectors separately. With all of your mods you will probably need a custom tune anyway. Call Procharger at 913-338-3086. I have found them to be very helpful.
Check out this http://www.jmschip.com/shop/product_...roducts_id=386, they've got it listed for $3899 since you already have an upgraded maf and fuel pump, the only other thing you need to buy would be injectors. 42# green tops Highly recommended.
ORIGINAL: tbirdscwd
Check out this http://www.jmschip.com/shop/product_...oducts_id=386, they've got it listed for $3899 since you already have an upgraded maf and fuel pump, the only other thing you need to buy would be injectors. 42# green tops Highly recommended.
ORIGINAL: brock_07
or he could go to rpmoutlet.com it would be about the same price as jmschip.com but u got the 10 psi pulley option at no extra cost
ORIGINAL: tbirdscwd
ORIGINAL: brock_07
ORIGINAL: tbirdscwd
I remember back in the " chevy " days when I considered sticking a 8-71 blower in my chevelle, I was told that if I had a bolt on part that added 5 hp and I supercharged my car, the part that once gave me 5 extra hp would now give me 10 hp. Whether thats true or not ,????
