blowing engine from running too rich??
Old 04-07-2008, 12:29 AM
racer02GTstang
racer02GTstang's Avatar
Default blowing engine from running too rich??
i was told you can blow your engine by running to rich at work today? is that true. they have been telling me im gonna blow mine since its running real rich. i thought all that can really do is foul plugs and 02 sensors, etc... it doesnt run so rich that it wont run... you can just smell it through the exhuast some, yet my exhuast has no cats.
racer02GTstang is offline
Old 04-07-2008, 12:39 AM
timeformiller44
timeformiller44's Avatar
Default RE: blowing engine from running too rich??
if you lean it out badly you can blow it...running rich..you can foul out plugs/plug cats/clog up o2's and have some carbon build up...but i really dont think rich will blow you up.. lean will tho i mean the more lean u go the more power but thats why u get tuned right so u lean out to the safest spot you can
timeformiller44 is offline
Old 04-07-2008, 05:10 AM
oxfordgt
oxfordgt's Avatar
Thats pretty funny. I don't think i have ever heard that. No you can not blow from running rich. No you will not ruin your 02 sensors. Yes you will burn up your cats (but you dont have any). The rich run limit is 9.5:1, black smoke will start at 10:1, you can foul plugs at 10.5:1 Which it will idle rough. You dont really have anything to worry about.
oxfordgt is offline
Old 04-07-2008, 10:23 AM
racer02GTstang
ok. thats good to know. thanks guys... another mechanic told me that that is pretty knowledgable so i wanted to double check him before listening. he said something about wetting the cylinder walls or something and gas getting in the oil and such... but i thought that would only happen with bad piston rings. it does idle rough but that is from the cams.
Old 04-07-2008, 10:32 AM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
He could've meant that you could wash out the rings and get fuel in the oil, possibly. Ask him to be more specific than "blow" the motor. Sucking a small animal into your serpentine pulley system could "blow" the motor too.
35thAnni99GT is offline
Old 04-07-2008, 11:47 AM
98SN95
98SN95's Avatar
why is your motor running rich in the first place?
98SN95 is offline
Old 04-07-2008, 12:45 PM
BlackMage
BlackMage's Avatar
you shouldn have a problem running rich, mine runs rich but it runs great, if your running rich the extra gas is helping to cool down the cylinder walls and piston, when you run lean there is nothing there to really help cool it down a little bit, and it gets hot and then it goes boom lol
BlackMage is offline
Old 04-07-2008, 02:09 PM
35thAnni99GT
ORIGINAL: 98SN95
Well, when running F/I your optimum A/F ratio is going to be between 11.0-12.0:1 unless you're running some of the good stuff.... By that I mean C15 or better.
Old 04-07-2008, 09:09 PM
racer02GTstang
im not running FI right now though. im still n/a waiting on my turbo kit. heh.
he said i can blow it and i can also wash out the rings getting fuel in the oil.
Old 04-07-2008, 09:12 PM
racer02GTstang
ORIGINAL: 98SN95
has a ton of work with a fuel system and no tune.
Quick Reply: blowing engine from running too rich??
