Having problem cold start up
Old 04-16-2008, 01:45 PM
35thAnni99GT
35thAnni99GT's Avatar
Location: Where gunshots are more common than birds chirping
Default RE: Having problem cold start up
So does it start first time or do you have to sit there and keep the starter cranking for awhile
35thAnni99GT is offline
Old 04-16-2008, 02:13 PM
Saleen108
Saleen108's Avatar
It starts right up with rough idle 10-15 secsthen dies the first. Not having to crank over alot.
Saleen108 is offline
Old 04-16-2008, 02:24 PM
35thAnni99GT
Dies even if you try to pedal the gas and keep it running?
Old 04-16-2008, 02:44 PM
GodAmGT00
GodAmGT00's Avatar
I'm sort of stumped.. If your COPs are good, and you've determined the plugs are good.. I'd say check your CPS.. I'm not sure as to the procedure for doing so.. It could even be a sticky IAC... When you say puff of smoke, I'm assuming it's black smoke...
JT
GodAmGT00 is offline
Old 04-16-2008, 09:52 PM
Saleen108
Saleen108's Avatar
ttt
Old 04-17-2008, 08:25 AM
Saleen108
Saleen108's Avatar
Anybody have any other advice. PLEASE
Old 04-17-2008, 08:35 AM
GodAmGT00
GodAmGT00's Avatar
Did you own the car before the blower?? If so, has it always done this since then?? Can you think of anything else you've done to the car with regards to the fuel system/ignition system?
JT
Old 04-17-2008, 11:29 AM
Saleen108
Saleen108's Avatar
No i bought the car with the blower on it about 6 months ago. Ran great for about 4 months and now this.
Old 04-17-2008, 11:50 AM
GodAmGT00
GodAmGT00's Avatar
Have you tried unplugging the battery for a minute to reset the PCM?? I'm trying to start simple, and see if there are ways to completely eliminate some of these things that I've mentioned..
JT
Old 04-18-2008, 07:58 AM
Saleen108
Saleen108's Avatar
I have tried to to reset it. And still the same thing. This car is really starting to be a pain. Does this every cold start, but after that the car runs so strong. Anybody want to buy a Saleen?
Quick Reply: Having problem cold start up
