Im wanting to seafoam and i dont know exactly what/where the pcv valve is. If anyone can post a picture that shows what and where i need to disconnect so i can put in the seafoam i would be greatly appreciative. thank you.
If I remember correctly u can use any vacuum line thats attached to the throttle body, if u let it suck it to fast it will stall nice and slow then wait for the smoke show.
pcv is loacted on right side vavlve cover, ur intake arm in probably hiding it. find it follow the little plastic tubing into the plenum. start the car, then remove that line. the car is gonna wanna die as you pour it in there, so go slow. hope that helps.
