help asap, knocking sound
Old 02-19-2009, 04:34 PM
br99
br99's Avatar
Default help asap, knocking sound
I have a 99 gt and when i start it i get a knocking sound from the driver side bottom of the motor it only last about 15 20 seconds then stops and only does it the first time i start it for the day after that i can cut it on and off all day and it wont do it. Any help is appreciated, could it be crappy oil or something i just got the car a few weeks ago but i never drive it.
br99 is offline
Old 02-19-2009, 08:52 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Piston slap isn't all that uncommon up until 02. Have a compression test done to start. Get a mechanics Stethoscope and listen, that knock may not be going away like you think.
Dan04COBRA is offline
Old 02-19-2009, 09:09 PM
mustangman03
mustangman03's Avatar
The tensioners might be leaking down mine does that also if i let it sit for a while. I know a guy that has a 5.4 that rattles real bad for about 30 mins. and its been doing that for 50,000 miles just have it looked at b/c it is hard to diagnose noises over the internet.
mustangman03 is offline
Old 02-19-2009, 09:19 PM
br99
br99's Avatar
I am gone try changing the oil 2mrw, bc the only time i hear it is on the first start a the day and only for a couple minutes, it doesnt seem to be running any different, doesnt idle bad or miss or anything else, i have a steeda timing adj it only set at 12* and i always use 93 oct and use seafoam in ev other full tank
br99 is offline
Old 02-20-2009, 11:08 AM
br99
br99's Avatar
anyone esle any thoughts
br99 is offline
Old 02-20-2009, 11:20 AM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
sure its at the bottom? mine does it...its just a stuck lifter, no big deal
or it could be your timing chain tensioners going bad...theres a sticky about that
99BlackPonyGT is offline
Old 02-20-2009, 06:07 PM
Tazzy
Tazzy's Avatar
Make sure you are using the stock motorcraft oil filter or a k&n oil filter, these have the anti-drainback valve installed. What happens is all the oil drains out of the oil filter after sitting for a couple hours and when you first start the car you have no oil pressure until the filter fills back up. But this should only take around 3-5 seconds. If you are getting 20 seconds worth of rattle than it is probably piston slap. I can't beleive ford put the filter horizontal on these motors, vertical would have been much better.
Tazzy is offline
Old 02-20-2009, 08:36 PM
br99
br99's Avatar
well i just changed the oil there was no metal on the drain plug and the oil lookd fine, now it seems to do it worse than b4, but the car still runs fine, i have no clue what now.
br99 is offline
Old 02-21-2009, 08:37 AM
99BlackPonyGT
it doesnt sound like piston slap at all!!! dont listen to that garbage...piston slap doesnt just suddenly disappear
timing chain tensioner or valve tick is the most likely reason
Old 02-21-2009, 02:23 PM
br99
br99's Avatar
deff not valve tick it is metal to metal, an now appears to do it all the time, it sucks bc i have put maybe 500 miles on the car since i bought it, and it is n excellent shape has new everything. but i startin to get mad now bc i cant drive it bc i dont know what gone happen
br99 is offline
Quick Reply: help asap, knocking sound
