Snake Under My Hood?? Help
Old 06-14-2005, 01:55 AM
Blinkstang
Blinkstang's Avatar
Default Snake Under My Hood?? Help
So I have an 02' GT, that apparently thinks its a Cobra because it likes to hiss at me. When my car is idle or at a stop, it makes this on and off hissing sound. It could be happening when Im moving as well and I just do not hear it over driving noise.
Its coming from the engine, I opened the hood and its real loud when open. It hisses as I said, on and off. So like hiss hiss silence hiss hiss hiss silence. The silence is only like for a second or less. Is this normal or do I need to call animal control? My driving is normal and it does not seem to affect anything, so I thought it might just be a normal engine sound. But I do not remember having this sound on my previous 96' GT. Do I have an air leak of some sort? Thats what it basically sounds like, hissing air shooting out.
So what is it? Bad? What should I do?
Thanks guys!
Info:
2002 GT, Manual
No Engine Modifications (Yet...)
(Happens with A/C On or Off)
Blinkstang is offline
Old 06-14-2005, 01:57 AM
Guest
Guest
Posts: n/a
Default RE: Snake Under My Hood?? Help
Sounds like either the radiator itself or a vacuum leak to me. Does it idle funny at all when it does it?
Old 06-14-2005, 02:04 AM
Blinkstang
Blinkstang's Avatar
No it pretty much idles the same, from what I have noticed it doesn't affect anything.
Old 06-14-2005, 02:05 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
Sounds to me as though you have an exhaust leak.
jdaniel is offline
Old 06-14-2005, 02:26 AM
Blinkstang
Blinkstang's Avatar
ORIGINAL: jdaniel
Would that noise come from the engine? I have the stock exhaust setup. How can I tell if it is?
Old 06-15-2005, 03:53 AM
4.6-GetBlown
4.6-GetBlown's Avatar
I get the same noise in mine... I was just assuming that it was my MAM.
4.6-GetBlown is offline
Old 06-15-2005, 10:45 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
ORIGINAL: Blinkstang
ORIGINAL: jdaniel
Yeap. It will sound as if its coming from a valve cover. If it gets bad then you will hear a ticking instead of a hiss. Its from your exhaust manifold(s).
jdaniel is offline
Old 06-15-2005, 12:48 PM
josh_0351
josh_0351's Avatar
My 02 GT does the same thing, but I'm not too concerned with it.
josh_0351 is offline
Old 06-15-2005, 02:04 PM
Acer2428
Site Mod
Acer2428's Avatar
same.
Acer2428 is offline
Old 06-15-2005, 05:35 PM
josh4rim
josh4rim's Avatar
Make sure you check the temp. of your car. Make sure it is not over heating. Also check for leaks in the intake or exhaust. Could be vacuum lines. Any thing that may suck or blow air. But the most common thing is leak in exhaust manifold or an over heating radiator if the car is idling normal.
josh4rim is offline
Quick Reply: Snake Under My Hood?? Help
