transmission ????'s
transmission ????'s
im thinkin about swapping my automatic to a manual. someone offered me a tko500. now assuming i have the tranny, what else would i need to buy besides the clutch, pedals, flywheel and clutch cable??? and how much will this stuff cost roughly AFTER i have the tranny
btw is the tko hard to install? i heard some are harder than others??
thanks a bunch guys!!!
I did a T-3650~T-56 swap several months ago, but was not as extensive a mod as you plan. I went T-56 due to the much better driveabilty in ratios and old trans was dying anyway.
This will give you an idea of what is needed anyway. If you go T-3650, I have an aluminum DS for ya if interested.
Jazzer
Jazzer
Transmission Help
Sounds like a big PITA to me, lotso custom fabs, yer gonna need the new center consol, driveshaft, just installing a clutch pedal where there isnt one is going to be a fun one. You cant beat the consitancy of an auto anyways, get a tuner and be done with it or buy a car with a manual trans already. Cheaper in the long run. I estimate if you do the job yourself your looking at about $500-$1000 at least to do it right, the clutch/flywheel/Steeda adjustible clutch cable kit alone will be over $500. Plus depending on your sceduale your looking at at least a couple of weeks.
custom fabs? The console is the same, you just swap out the bezel and shift boot. The driveshaft might still work (i did an AOD-T5 swap in my fox and reused the same d-shaft and x-member) The pedals arent custom either. You unbolt the brake pedal assembly and install the brake/clutch pedal assembly in its place. Its not the funnest job, but it surely isnt fabricating.
Though never attempted in my own vehicle...I would not recommend eating a meatball sub and driving...stick or auto
