Idle Misfire
RE: Idle Misfire
i have the timing adjuster set at 4 deg advance giving the car a total of 14 deg advance, thats the max i heard u can go without det. if i had it at 10 deg there would be a total of 20!!
RE: Idle Misfire
I don't think you quite understand how to use that timing adjuster. You need to adjust it to the 10 on the bracket...THEN you'll be back at stock timing. I recall going through all this with you once before in a previous thread...
Going all the way back to 0 is whats making your car idle like crap.
RE: Idle Misfire
ORIGINAL: Dan02GT
Uh huh.
RE: Idle Misfire
ORIGINAL: Dan02GT
RE: Idle Misfire
Hey dan, did you ever figure anything out about the timing adjuster?? and on a side note mac's timing adjuster is set up different than steeda, mac's goes 10 9 8 7 6 5 4 3 2 1 0 1 2 3 4 5 6 7 8 9 10 where steeda goes 0 1 2 3 4 5 6 7...etc all the way up to 20.
