LCA's would be my suggestion. They are designed to eliminate wheel hop (if you have any). You can get a decent set of uppers and lowers if you look around.
If you could only pick ONE which would it be and why?
I can afford to get one of these items right now. Also should I go for the double adj. ones? or no?
thanks
I would say springs, just because the stock 4x4 height is terrible, even though this is about 1/4 times. Summit sells a set of both LCA/UCAs for around $150
my first upgrade on suspension was eibachs drag springs with airbag. its taken me to the 12s. im starting to work on suspension now. chromoly k member and coilovers will be here tomorrow
I would hope you will be in 12's anyway with that power.
