Worried About Spark Plug Blowout
Old 05-31-2009, 06:47 PM
X6StringerX
X6StringerX's Avatar
Default Worried About Spark Plug Blowout
I placed my order a few days ago for some NGK V-Power plugs, but decided to do some reading about the 4.6 after that. From what I gather, this plug is regarded highly but I discovered the dreaded blowout issue that so many people have been experiencing. Now I'm scared that I'll suffer from it as well. It seems that it's happening shortly after a lot of people have replaced their plugs. I've found arguments for and against the use of anti-seize, for and against Motorcraft or other brand plugs, and arguments about a warm engine vs. stone cold engine while changing plugs. In the past, I've never used anti-seize and I've always changed the plugs while the engine was cold or at the most only operating for a couple minutes. I've never used a torque wrench on them... just went by the feel. I take it I should use much more caution this time around. 13lb. ft. seems to be the magic number.
My car is a 2000 GT with 66k miles. I really want to do a tune-up and I've already ordered everything... should I lose sleep over this?
X6StringerX is offline
Old 05-31-2009, 07:33 PM
Obsequious1
Obsequious1's Avatar
I check my plugs every oil change and sometimes inbetween now that mine has blown out.
Doesn't hurt to check 'em.
Obsequious1 is offline
Old 05-31-2009, 10:44 PM
MustangMan00
MustangMan00's Avatar
i just put some ngk g power plugs in my car, i had v powers before, ngk's are good plugs IMO
changed em on a dead cold engine
hand snugged them down to my specs
2nd time ive changed the plugs, no blow outs...trust yourself
MustangMan00 is offline
Old 05-31-2009, 11:28 PM
72MachOne99GT
2010 Blue Ball Award Recipient
72MachOne99GT's Avatar
torque wrench.
end of discussion
72MachOne99GT is offline
Old 05-31-2009, 11:35 PM
isjoining
isjoining's Avatar
i changed my plugs for the first time a month ago using a torque wrench, no blowouts
isjoining is offline
Old 06-01-2009, 01:32 AM
X6StringerX
If it's as simple as just using a torque wrench, then I'll worry a little less. However, after reading a bunch of threads, I just kind of get the feeling that it's a shot in the dark... some are lucky and some aren't.
Old 06-01-2009, 07:25 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Changing the plugs is easy... You can use a torque wrench or not. I havent used one on any of my vehicles... I know how tight the plugs should be... Never had any issues.
WhiteFoxGT is offline
Old 06-01-2009, 01:17 PM
johnsstang
johnsstang's Avatar
Sorry im new, what's spark plug blowout?
johnsstang is offline
Old 06-01-2009, 04:34 PM
BC 00GT
BC 00GT's Avatar
I pulled mine out to look the other day and decided i needed a change but had to wait untill Friday!
Just used a torque wrench and went to 12lbs i am not worried as thats the standard i have read!
BC 00GT is offline
Old 06-01-2009, 06:13 PM
mustang_pa
mustang_pa's Avatar
I've changed my plugs about 10 times on my stang just cuz i was doing some testing with different kinds. I always make them snug, so when you go to loosen them, you just give them alitte umf to get them loose. That is how my dad taught me and has worked fine on every car i have owned.
Some mustang engines have 4 threads in them for the spark plugs and others have 6 threads so that the plugs hold in better. I think it is the older 4.6's that have 4 threads but i am not certian.
mustang_pa is offline
Quick Reply: Worried About Spark Plug Blowout
