vt stage 2 vs comp stage 2
Between vt's stage 2 cams and comp's (xe270ah) stage 2 cams, which one would you choose and why? These both seem to be the most popular stage 2 cams for our cars.
My car has full bolt ons with a 3.90 gear, and stock pi heads. It does have nitrous, but i really don't care which cams favor that because i rarely use it.
I've narrowed it down to these two, so i need some help picking the better overall one.
Thanks!
Thanks!
You're right...CMS...i forgot about that whole VT thing!l lol.
Now, with such a tight LSA, will i not gain much on the juice?
Also (since these seem quite agressive for n/a stage 2's) have there been any issues with getting them tuned right? Any drivability issues?
I'm really likeing the CMS stage 2, but the tight LSA has me concerned a little
You shouldn't have any tuning issues...if the tuner is competent. Here is a little info on these 2 cams. A couple years back, We had a customer that ran NMRA and FFW Mod Motor. He had Comp 270's. He ran the car on saturday at the track with the 270's. Pulled the car into the shop, swapped in my Stage 2 N/A...and went back out and made track hits. Same track, same weekend, same weather,etc,etc. My cams went 2 tenths QUICKER. They made peak HP within 2HP of each other on the dyno....but its the whole powerband that counts...as you can tell. So my smaller cam (10* less intake duration than the 270's) outran the larger cam.
I'm not looking for a "nitrous specific" cam, but i was wondering, with a 108 LSA, will it still do okay with my nitrous?
Have you ever had to fly cut the pistons (with stock heads and pistons of course) because of clearence issues?
Also where is the cheapest place to by these with springs?
Interesting! So yours made better power under the curve?
Are the Manley NEXTEK 2 valve springs the ones i should use?
Is there anything else i would need besides this?
