Control arms
Control arms
http://www.uprproducts.com/shopping/shopaddtocart.asp
Currently have summit uppers and lowers but there in bad shape. I want to upgrade to spherical end control arms and the housing bushings. Are those a good upgrade or should i look for something different. My budget is $600. I go to the track about 10 times a year. I'm still running 4.10's, novi 2000, and slicks when i go so I'd like to get something to handle 400+ hp.
EDIT: just relized i posted in the modular section and this should be in the 4.6 general section sorry
Your link is to an empty shopping cart at UPR, so not sure to which arms you refer, but would recommend a set of Griggs LCA's. The picture in that link is INCORRECT and just spoke to owner about it yesterday. The LCA is a poly/sperical set of adjustable LCA's, but picture is a set of poly/poly non-adjustable set. I was told the pic would be corrected, so may be OK by the time you see this post.
As for UCA's, I have always recommended UPR Pro Series:
Griggs doesn't make an upper arm, so unless you go PHB/WL and torque-arm, this is the best way to go, IMO.
Jazzer
Jazzer
Man, if i was going to spend 1400$ i'd go with a watts link from fays2 for sure. Its less than 700$ shipped...add to that what ever you like for shocks and uppers and lowers and you will have a fine a$$...err..rear end lol.
