car is falling flat on its face at like 3500-4k.
Those things arent easy to pull...lol
theres so much **** blocking access to them
That and Ive heard too many horror stories about them popping out or stripping the threads.
I dont have a torque wrench to torque them to 13 ft lb or whatever they need to be at so I dont know if I even want to touch them without a torque wrench
You have an 03 engine that has the extra threads. Pull them. I have never used a torque wrench while installing plugs and never once had a problem. 13ft lbs is just past hand tight.
I doubt you have anywhere near as much crap in the way of pulling your plugs as I do and it only takes 30min for me to change my plugs.
I am willing to bet that when you pull them you will have a couple that are destroyed.
Ok, thanks
Do you know what size I need for the plugs?
5/8 deep socket?
I changed the fuel filter, thats not it.
Im assuming its something in the ignition fuel system.
Could it be the coil packs?
I am running tr6's gapped at .30
They all look perfect...as they should, theyre only 3 weeks old.
What else could this be?
Failing fuel pump, stuck injector, bad coil packs?
bad gas maybe?
bad gas maybe?
If you have COP's I would check those too.
But if im correct your year doesnt have them.
How about the coil pack or spark plug wires.
really sound like a misfire or fuel problem to me.
Good Luck and hope you fix your stang
I dont know how to check coil packs or spark plug wires...but it does sound like a fuel problem or something
