Spark Plugs and Rear End Oil
As far as the rear end oil, put in the whale sperm limited slip additive first, then fill it with gear oil til it spills out, then cap it.
Any FLAPS should have the FM in stock--be careful with it as it stinks to high heaven (kind of like a sweet smelling cat ****). Spill it in your garage, or even in your driveway, and you'll be smelling it for months...
The spec is 4.25 pints, 2 qts + 4 oz of FM. Most synthetic gear lubes don't need the friction modifier, check the label...
But yes, grab some from your local ford dealer and you'll be set. Usually, if you buy the rear fluid from them they will tell you you need the FM and they can tell you how much fluid you need. I love our local parts guys, of course, I deal with them everyday.
ShaneB26154
35
03-04-2021 04:05 AM
inyadreems
08-21-2015 09:10 AM
