can someone explain coil bind?
Old 06-24-2009, 02:01 PM
massred98gt
massred98gt's Avatar
Default can someone explain coil bind?
exactly what the title says. i'm about to buy some cams, but i want a higher lift cam than companies offer for npi heads. so i'm looking at pi cams. i just want to understand all the cam bullSh*i before i go ahead and purchase. i asked 10inchterror (cms) about his stage one cam and he said that i would need springs and offset retainers for his cams to work. well i'm running pi cams with pi springs already so why would i need new springs when the cam advertises no aftermarket springs needed and why would i need offset retainers. sorry if this is a retarted question i'm just trying to understand everything
massred98gt is offline
Old 06-24-2009, 04:05 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
"Coil bind" happens when the lift of the cam, multiplied by the lift ratio of the followers, is so much that the valve spring fully compresses before maximum lift happens.
It is always bad, even if just a little bit, and to extremes it is VERY bad and will break something probably the follower, or timing chain.
Coil binding can also happen in coil spring suspensions, if the spring rate is insufficient and/or the shocks are too wimpy...
cliffyk is offline
Old 06-25-2009, 09:09 AM
nickmckinney
nickmckinney's Avatar
The stock retainer hits the valve seal at 0.540" lift on a NPI head.
Bullet now has both a Stage 1 and a Stage 2 cam that will work in those NPI heads without changing valve springs or retainers.
nickmckinney is offline
Old 06-25-2009, 05:01 PM
massred98gt
ooo i c. i was trying to find the specs on the npi valve train and couldn't find anything so i was confused why stock pi cams work fine but aftermarket one wouldn't. now the whole coil bind thing makes sense. thanks for the responses guys real helpful!!
now for the bullet cams. where can i find them to compare them to other companies price and performance wise?
Old 06-25-2009, 05:06 PM
cobra dreamer
cobra dreamer's Avatar
all cms cams are ground by bullet
cobra dreamer is offline
Old 06-25-2009, 06:04 PM
massred98gt
whats the deal with comp cams 268h. anybody used them. the numbers look good.
Old 06-26-2009, 08:12 AM
nickmckinney
Bullet cams
Old 06-26-2009, 08:13 AM
nickmckinney
They are kinda big duration for a stock NPI head motor IMHO (yes I have tuned a car with them).
Old 07-01-2009, 09:56 AM
massred98gt
can somebody explain to me the concept of duration. i know what it means but i don't know what the numbers mean. its the amount of time that both the intake and exhaust valves are open to create scaveging. great lol. but what do the numbers mean for example the bullet stage one cam duration specs (215/218 at .050 lift) what the heck does that mean. i know the numbers are measuring degrees in crank rotation but how does that relate to duration. enlighten me
Old 07-02-2009, 08:15 AM
nickmckinney
Duration is simply how long are the valves held open in crank degrees.
Granatelli Sales
03-25-2016 08:01 PM
Thunderball
15
11-22-2015 11:49 PM
firehorse02
11-16-2015 11:28 AM
Sixer4Life
09-28-2015 07:05 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: can someone explain coil bind?
