Cobra brake upgrade issues?
Well I just installed my 10th Anniv cobra brake kit I got from BFR. I also added the SS brake lines.
Kit installed fine, got it all buttoned up in about an hour but it feels like something is wrong. Right now the pedal is really difficult to push in. I don't think I could push the pedal to the floor if I wanted to. I mean we're literally talking maybe an 1" of travel before the brakes come on and than it's like trying to push a brick. The brakes grab fast but they don't really feel like they do a decent job stopping the car after the initial grab. Like the actual braking power feels weaker than it was before.
There also seems to be inconsistency in the pedal. It almost feels like something catching on something. I'm going to take them back apart to see if I can figure out what is going on... I just wanted to be 100% positive this isn't what they are suppose to feel like. and to see if anyone had any ideas.
The only thing I can even think that I did that was kinda out of the ordinary is the SS kit gave you 2 copper crush washers per side... So I used both of them, one on each side of the brake line... But other than that... I have no clue.
Confirm a couple things..
Make sure the "crush" washers do not block the passing of fluid through the SS lines.
Make sure you don't have grease or oil on pads that may limit the friction
Did you bleed the air from ALL the brake lines after install?
Jazzer
Jazzer
I did bleed all 4 corners afterward.
I just can't imagine the pedal being that stiff. If I never had to actually get into the brakes I don't think I would notice. For just casual braking it seems to work fine (actually stops better than before) but if you actually put your foot into it the car doesn't to much for stopping. And when you do put your foot into it, like I mentioned before the pedal feels like there is a catch in it and you can really hear the booster humming.
I guess to me it seems more like something interfering with the fluid in line because I can't imagine that there should be that much pedal effort needed and that would also explain the lack of heavy braking power.
Oh and the car doesn't pull one direction or the other during braking so I hate to assume both calipers are working or not working equally.
Well.... the first half of your above post makes me think the brakes NEEDED work prior to this upgrade. Maybe they already had some air in the lines and needed bleeding. This may account for why your pedal feels much more stiff since this work. On the other hand.... you were able to bleed the brakes on all four corners AFTER this upgrade, so we know the lines are clear. There is just a minute passage way needed for fluid to pass and compress the calipers. This means we can rule out a stoppage in the line possibly caused by the crush washers.
This is beginning to sound like a booster issue. You may have a vacuum leak or just a bad booster. Would seem odd that this happened during your work, so would look to see if you cracked a vacuum line connector during the fluid reseviour refill under the hood or maybe a line is damaged. Check all the connections and see if anything makes sense.
Jazzer
Jazzer
Jazzer
Jazzer
