Exhauast clamps vs. Welding
If anyone has used clamps or knows about them for sticking in some new mufflers, let me know. Any advantages/disadvantages are appreciated and if you have any recommendations to brand/types of clamps.
welded is the way to go... Sturdy especially because we eventually scrape the bottom somehow. Clamp-on gives you do it yourself features, interchangeable, but are sometimes a pain to fit, clamps break/loosen and prone for exhaust leaks.
id say go with clamps. my exhaust is clamped and it makes it easy to swap out mufflers if you wish or to take the exhaust apart.
just make sure you have the clamps tight enough and hang everything up right and you wont have any problems
Ok, for the clamps would i be better off with going with something like http://www.jegs.com/p/JEGS/JEGS-Pref...53274/10002/-1 or http://www.jegs.com/p/Dynatech/Dynat...53318/10002/-1
I like the clamps stlcardsfanp posted. I have a friend that used cheapo clamps and ended up ripping his mufflers off and dragging them backwards on the ground because he went over a bump and the clamps rubbed.
-Riggs
-Riggs
09-17-2015 07:57 PM
09-10-2015 08:39 PM
