I got nitrous , and want opinions
Old 08-09-2009, 10:55 PM
mustydakota
mustydakota's Avatar
Default I got nitrous , and want opinions
I got a good deal on a NOS kit for a 4.6 it has everything including window control that will spray only between 2500 and 5500 rpm. I am pretty much stock except for full 2.5 exhaust with h-pipe and gears.
Should I install IT???? I wont use it much and if I do I will install a 50-75 shot maximum. Is it that hazardous to my engine??? is it worth the risk of expense to install it ??
I hear people run zex kit with no problems for years but I do drive my car every day and I need it to be somewhat reliable. but also if some goof in a suburu pulls up and wants to give me a go id like to have the spray on my side.
Opinions suggestions please guys
mustydakota is offline
Old 08-09-2009, 10:58 PM
a_penquin
a_penquin's Avatar
idk about that range, might readjust. I normally go past 2500 on a daily basis driving normal. might bump it to 3500-4000 start.
a_penquin is offline
Old 08-09-2009, 11:00 PM
apeterman
apeterman's Avatar
I would say as long long as you install it right at a 50-75 shot you should be fine. nice pick up
apeterman is offline
Old 08-09-2009, 11:23 PM
mrtstang
mrtstang's Avatar
If you aren't going to have the car tuned, then a 50-75 shot should be fine. If you have it tuned properly you can throw a 100-125 shot all day long.
I've been running a 100 shot for over a year now, and haven't had a single issue.
As far as installing it? Well... that depends on your abilities. It's pretty straightforward for someone that has a little mechanical ability.
mrtstang is offline
Old 08-10-2009, 01:12 AM
SilvrStang
SilvrStang's Avatar
I agree of geting an RPM window switch that way the nitrous can hit inbetween 3000-5500. If you really wana be bad *** about it you can hide the nitrous solenoids into the fender lol we did it on my buddys car and ran a line through the carpet and hid the bottle in the trunk. Its pretty sick.
SilvrStang is offline
Old 08-11-2009, 02:06 PM
rthouck
rthouck's Avatar
You'll be fine with that low of a shot....
rthouck is offline
Old 08-11-2009, 02:23 PM
rman101
rman101's Avatar
he has a window switch.
do you have an activation switch or a wot switch though?
agreed you'll be fine with it. go for it.
rman101 is offline
Old 08-11-2009, 03:16 PM
dimebag
dimebag's Avatar
My opinion...that small of a shot is a waste of time. Spray 100.
dimebag is offline
Old 08-11-2009, 03:41 PM
loweredfourpointsix
loweredfourpointsix's Avatar
would 125shot w/o a tune be unsafe for the motor? what about 100shot?
loweredfourpointsix is offline
Old 08-11-2009, 03:48 PM
mrtstang
mrtstang's Avatar
Some do it, but i wouldn't even consider it.
mrtstang is offline
Quick Reply: I got nitrous , and want opinions
