Old 10-08-2015, 01:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
How do I flush/replace the power steering fluid
Old 10-28-2009, 07:30 PM
DreamerGT
DreamerGT's Avatar
Default How do I flush/replace the power steering fluid
How is it done? Mine is brown and nasty looking. I cant believe I let it get like that.
DreamerGT is offline
Old 10-28-2009, 09:22 PM
PaintballFreak
PaintballFreak's Avatar
I believe the best way is to follow the hose down from the reservoir to where it meets the pump area. Around there at about the lowest point in the system there is hex head fitting (I think). If you loosen it, fluid will just start to drain out. Once it's drained, tighten it back up, fill the top with fluid and then purge the system of air. To do that, you need to work the steering wheel all the way to it's limit 2 or 3 times. Turn all the way left, then back all the way right, then left, then right. More you do it, more likely to get all the air out. Then make sure the level is high enough and you should be good.
PaintballFreak is offline
Old 10-28-2009, 10:58 PM
DreamerGT
DreamerGT's Avatar
sounds easy, thanks
Old 10-29-2009, 01:52 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
From the '03 shop manual...
cliffyk is offline
Old 10-29-2009, 02:10 PM
DreamerGT
DreamerGT's Avatar
thanks again cliffyk
Old 10-29-2009, 07:25 PM
01MGGT
01MGGT's Avatar
Also note that they you shouldn't hold it at max stops for long at all. You will know when you hit them because it sounds like a whine.
01MGGT is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
stark777
09-21-2015 12:46 PM
BOBCATJACK
09-14-2015 02:18 AM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
Quick Reply: How do I flush/replace the power steering fluid
