catalytic converter question
I recently stumbled upon a o/r x pipe and i want to install cats to keep the car from running in "safe" mode. My question is, will universal 3 step cats work, or will i have to buy obdII compliant c ats to keep the engine from running rich?
Thanks
Thanks
Buy a tuner and turn the rear o2 sensors off. I am a little confused as to why you would buy and/or install an O/R midpipe and then want to install cats. Why not just buy a catted mid pipe?
There is something else wrong if indeed the engine is sluggish--however it may just be the niose effect. When you installed the o/r pipe I bet it got a lot louder and until you get used to it you mind will be uncomfortable that the noise and performance levels don't seem to match...
Yes, pretty much the rear O2s make sure the catalytic converter functions correctly...If clogged, broken or not present, it will trigger the CEL by reading a different voltage than suppose to. It is also said that the rear O2 can compensate small amounts of fuel (air/fuel ratio) for the degraded catalyst. Ford says that it only has a +/- .5 fuel control authority.
The fuel trim and catalyst monitoring decriptions in the shop manuals I have make no mention of the rear sensors having anything to do with closed loop fuel trim control, nor do any of system diagrams, or the Ford OBD System Operation Manuals that I have read.
The PCM can force the mix rich and lean in attempting to jolt the rear sensors back to operation (normally only with a "green", less then 500 miles, cat), however this is just a transient test condition initated by the PCM when the rear sensors are "stuck"...
don't remember where i read that....just remember something like that. But i do agree that their main purpose is to maintain catalytic efficiency. It could be that i read that differ manufacturers use the rear for multi-purposes as in changing air/fuel if catalytic failure or degrading occurs. But i read it was very very minimal change. Or I could have read wrong.
