clutch question?
Old 08-19-2009, 04:15 PM
alkureg
alkureg's Avatar
Default clutch question?
yeah i got a v6 but a clutch issue is a clutch issue. Basically my pedal responds different everytime i get in the car, some days its really soft and light and then the next day its really hard to press, and it goes everywhere in between. it feels like its not disengaging and sometimes its hard to put it in gear but all the way but theres no slack or twisting/binding in the cable. i cant really look to see if its been knocked out of place because i dont have a lift. anyone had this happen or know what it might be? and yes ive been a bit rough on it before cause someones gonna ask. Thanks yall
alkureg is offline
Old 08-19-2009, 05:03 PM
bs46488
bs46488's Avatar
I'm not 100% sure, but I think the answer is going to be "that's just the way a cable clutch is"
Mine does the same thing. Both when it was stock and now as a Spec Stage II with replaced quadrant.
If there is a solution, I'm in, because mine still does it.
bs46488 is offline
Old 08-19-2009, 05:10 PM
alkureg
alkureg's Avatar
eh mines a spec stage 1 but it just started doing it recently after running hard so i figured i did something to either the clutch or tranny
alkureg is offline
Old 08-19-2009, 05:25 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
This sounds like the clutch fork is partially sliding off of the pivot ball in the bell housing.
Try this.... jack the car up so you can get access to the cable connection at the side of the bell housing. Remove the aluminum cover and push the fork straight inward into the bell housing. If you feel it move inward slightly, jump in and see if the clutch is now easy to oporate.
This happened to me and was a total PITA to shift sometimes and would either grind going into gears, or just not disengage completely. Let us know if this helps situation.
Jazzer
Jazzer The Cat is offline
Old 08-19-2009, 08:10 PM
alkureg
alkureg's Avatar
wow that seemed to do the trick! the cable is feelin the way it used to and for a trip to the local mall it stayed constant, thanks alot jazzer heres hopin it continues to work!
alkureg is offline
Old 08-19-2009, 08:37 PM
Blk003GT
Blk003GT's Avatar
is that a rousch emblem?
Blk003GT is offline
Old 08-19-2009, 08:41 PM
alkureg
alkureg's Avatar
no its the 'stang' emblem from autobadges.com
alkureg is offline
Old 08-20-2009, 07:50 AM
Jazzer The Cat
Retired Moderator
If that solved the problem, it will likely return, unfortunately...
The clutch fork is sliding 1/2 way off the pivot bolt and being "driven" into the sleeve in which the TOB travels. When this happens, you get the resistance and your clutch does not travel the full distance to disengage the trans. Mine did this and took me a while to figure it all out, so this pivot bolt was damaged. You may be able to get away with pushing it back inward for some time, I just don't know.
Jazzer
AmericanMuscle4.6GT
11-10-2015 02:06 PM
MasterLanMan
09-13-2015 08:21 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: clutch question?
