Gt Supercar Fuel Pump
Can i use this fuel pump with my build? its far less expensive than the aeromotive pump. Again i'll be pushing around 550hp, do have an inline pump, will have 60lb injectors.. .it also says wiring modifications will have to be done, if i can use this.. what kind of mods will have to be done?
ha, if you asking me, which i don't think you are, i'm not running anything just yet, just stock fuel system. was looking into the bap options with the amercian muscles's 255lph pump and 60# injectors... think tha'd work for my build? 550 or so hp with procharger
I would consider trying to do all the mods first. Since the SC requires a tune, every time you change something you'll need to go back to change the tune.
Personally, I installed a 255lph pump in my '01. it was the limiting factor in getting more HP from my supercharger. Basically I was maxing out the fuel pump trying to get fuel up front. He told me ways to get more fuel up there, then of course it needs a new tune...
But my set up is returnless, your car is a little different, so it could be different. There is an amazing fuel set-up on this page. I drool every time I look at it....
https://mustangforums.com/forum/4-6-...l-systems.html
The fuel pump you want to run, 255lph is not designed for variable voltage so in turn the pump will fail after awhile if you use a boost-a-pump
As I said before at the power you are looking at you are gonna have to go with a larger setup that includes fuel line upgrades, at least 60lb injectors, and upgraded fuel rail as the 96-98 Cobra rails are not even as good as 96-98 GT rails and of course a better pump.
