how to test a maf
I don't see why not, and frankly the opinion of the "dude at autozone" as to what's wrong, based upon pulling codes with a generic scantool, is pretty much worthless.
Get the codes and look 'em up here...
p0102 Mass Air Flow (MAF) Circuit Low Input
p0175 System too Rich (Bank 2)
p0172 System too Rich (Bank 1)
i put seafoam in the brake booster vac line before i started driving the car, could it have done harm?
so 102 is saying the maf is messing up and the other 2 are saying the car is running rich. i pulled the maf sensor off and its clean so how do i check it?
Seafoam was developed in the 40's for use in marine engines (hence the name) that habitually ran cold and/or were otherwise poorly maintained or stored unused for extended periods (think winter, in a shed on a wharf in Maine).
It has no place being used in a modern properly maintained engine. Ford specifically states in its manuals that snake-oil intake "cleansers" and oil additives should NOT be used under any circumstances. If I owned any engine that could possibly benefit from Seafoam I'd take it apart an rebuild it...
Here are the reference values from the '03 shop manual:
Depending on where the Seafoam was injected it may have contaminated the MAF as the intake air pulsed. Many have cleaned their MAF successfuly with rattle can TB cleaner.
The O2 sensors may also have been contaminated/damaged by the snake-oil, depending on how fast and how much was ingested. They may burn themselves clean after a while, you might try taking the car for a 20-25 trip on the interstate.
i said this is on my crown vic, it has a brake booster vac line. i did do more than the can reccomends. its actually still smoking from it(or atleast i think).
that actually might be my answer.
eff me
eff me
I'm sorry, I missed that--a good long cruise on the highway may blow 'em clean...
Sure it could, if it contaminated the MAF or O2 sensors, which are designed to have gasoline mist, and gasoline created exhaust gasses thrown at them--not kerosene and who knows what else...
