Power steering and brakes went out. Please help!!!
Old 11-02-2009, 11:18 PM
kongdong
kongdong's Avatar
Default Power steering and brakes went out. Please help!!!
When I was on my way to work coming back from lunch (Subway rules!!!) I was getting back on the street to head back to work. I got on the street and was at about 3000RPMS and then I shifted in 2nd gear. In 2nd I went to 4000RPMS and that's when I noticed that my brake felt like iron. I couldn't push it down to save my life and the little I did I noticed barely made the car stop. To make matters worse when I go to make a turn the steering wheel felt like it was 100lbs heavier and I had to put my entire body weight into it to get the darn thing to turn just a little bit. Anyone have any idea what this could be? I need to get this fixed ASAP! I need my car and don't want to risk getting into an accident. Any ones help would be greatly appreciated.
kongdong is offline
Old 11-02-2009, 11:40 PM
JC316
JC316's Avatar
Did you break the belt? Any warning lights come on? The brakes are run off from the power steering, so the pump could have gone bad, or a line could have busted. I need more info.
JC316 is offline
Old 11-02-2009, 11:43 PM
kongdong
kongdong's Avatar
The belt is still there. No check engine light came on. The brakes are new. Hope that helped.
kongdong is offline
Old 11-02-2009, 11:51 PM
JC316
JC316's Avatar
Something might have happened to the hydro boost. That and the power steering pump are the only things that can affect the brakes and the steering. Check to see if you have any power steering fluid, if not, you may have busted a line somewhere.
JC316 is offline
Old 11-02-2009, 11:56 PM
kongdong
kongdong's Avatar
power steering is full..............what now??????????
kongdong is offline
Old 11-03-2009, 12:22 AM
JC316
JC316's Avatar
Either the hydroboost or the power steering pump. Probably the hydroboost, the power steering pump usually makes an awful racket when it's going out.
JC316 is offline
Old 11-03-2009, 01:53 AM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Ya he would hear if it was the power steering pump.
WannaBeGearHead is offline
Old 11-03-2009, 06:48 AM
kongdong
kongdong's Avatar
Is the hydroboost something that normally goes out?
kongdong is offline
Old 11-03-2009, 12:05 PM
JC316
JC316's Avatar
I have heard of a few going out. Seems like the only logical thing to me.
JC316 is offline
Old 11-03-2009, 02:43 PM
03BottleFedGT
03BottleFedGT's Avatar
its the hydroboost, they go out more often than people expect. when i worked at ford i was replacing those things all the time
03BottleFedGT is offline
Quick Reply: Power steering and brakes went out. Please help!!!
