help electrical issue :/
hey guys need some help with my 99 GT. when I trie to crank the car I can here a clicking noice in the starter relay.... so I would like some info of what could it be.... maybe replace the relay?? I am getting frustrated cuz its almost a month like this... I want to drive my baby again..
New battery could be discharged, but if it is that may indicate an alternator problem. Did you drive it a bit after putting the new battery in the car? Check battery voltage if you have a meter, and I am thinking it is low. Low voltage and cranking amps will cause a clicking noise. Good luck.
LARRY
LARRY
well I installed the new battery after the problem. I did not replace the starter but I did remove it because I replace the cultch not long ago... yesterday I turned the car on by pushing it(standard tranny) drove around town came back turn the car off and when I wanted to turn it back on the same clicking noice and no start, I guess I am going to push started from now on when ever I want to turn the car on lol
