Hey Guys need alittle help
Hey guys when I turn the wheel all the way left or right i hear a squealing the whole time the wheel is turning left or right. What could this be? and also if the parking brake line needs to be lubricated where is it located and what does it look like? Its also making a noise.....i think.
Is the squealing noise coming from under the hood, like a belt slipping? Or from near the wheels? If it's by the wheels, might be a balljoint like the post above suggests. If it's under the hood, have somebody turn the wheels while you watch the power steering pulley, see if it's trying to lock up. Also, does the sound happen only when the car is parked or moving slowly, or at any speed?
It is the power steering pump working at the max output. Fords, Chevy's, Mopars, and even imports do it. Check the fluid, it may be low, if not the pump is showing its age, but its normal and nothing to worry about.
The parking brake looks like a cable. Follow it from the rear calipers and use some wd40 where the cable is exposed.
I squeal around town all the time, hence the need for new tires....
/end thread/
