help*** new manifold, now car runs terrible
Old 12-29-2009, 07:03 PM
dallase46
dallase46's Avatar
Default help*** new manifold, now car runs terrible
2003 mustang gt 5 spd
I replaced the plastic manifold with a new one last night and here are my symptoms:
the bad:
1. When starting from cold the car runs fine until warmed up.
2. Once warmed up, it idles rough and has a miss.
3. Car has a loss of power and bogs as you accelerate.
4. If you feather the throttle it will accelerate better, if you mash the throttle, the back will bog pretty bad.
Things I tested/checked:
1. I used my smoke machine to test for manifold leaks and there are no vacuum leaks.
2. No water in the spark plug tubes.
3. Everything is hooked back up.
4. I taped the EGR and the IAC and the idle changed slightly.
5. My Genisys Scanner detected a misfire on cylinders 5 and 8, so I swapped coil packs on those and still does it, BUT NO check engine light.
6. All fluid levels are good.
7. I have unplugged every injector and coil one at a atime and it changed the idle.
I am at my wits end, please help.
dallase46 is offline
Old 12-29-2009, 07:25 PM
gouldie1903
gouldie1903's Avatar
sounds like the same boat i'm in. i replaced my gaskets and i'm having similar problems. the cold is slowing me down a bit but i'll let you know what fixes mine when i figure it out.
gouldie1903 is offline
Old 12-29-2009, 07:32 PM
00_buck
00_buck's Avatar
the bad:
same thing happened to me. I replaced my spark plugs and coil packs because they had over 100,000 miles anyway and it fixed my problem. i upgraded to MSD coil packs and they're great. i know thats expensive so you can use an air hose to blow those cylinders to be sure to get any foreign material you may not see. Also pull the coil packs out, take the rubber boots off and make sure they're dry internally. This system is very sensitive and just a drop of oil, fuel, or coolant will cause a missfire inside the boot. also go head and replace the ones that aren't firing; spark plugs are cheap so why not?
00_buck is offline
Old 12-29-2009, 09:19 PM
smitty2919
smitty2919's Avatar
i would take a guess at something like ignition related. on my 95 mark 8 i replaed a manifold and turns out i has 2 spark plug wires switched and it was doing the same thing you describe.
double check all is where it should be, if so then look into park plugs?
smitty2919 is offline
Old 12-29-2009, 09:40 PM
JC316
JC316's Avatar
Coil on plug, no wires.
I am going with bad coils too. They have a tendency to be touchy.
JC316 is offline
Old 12-29-2009, 09:54 PM
5sp04GT
5sp04GT's Avatar
+1 on the coils.
5sp04GT is offline
Old 12-30-2009, 05:35 AM
smitty2919
smitty2919's Avatar
well yes i know, but i was just saying that it may be something ignition related. hence the "on my 95 mark 8" lol
djbigskrilla
09-20-2022 01:04 AM
jjwinel78
08-17-2015 03:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: help*** new manifold, now car runs terrible
