Car is bucking.
Car is bucking.
Hey guys.
I just purchaced an 02 gt 5 sp. I just threw a code because when i was driving the other day my cel came on. I didnt feel any difference such as rough acceleration or idle, but i do notice that when i start from a stop light first gear seems fine but when i shift to second and get back on the gas the car seems to kinda buck, like its jerking in a way. It also does this if i am just cruising and punch it to the floor. There seems to be som hesitation. For some reason i dont think that the cel has anything to do with it but maybe im wrong.
Not too concerned at this point since i have a 2yr bumper-bumper warr. Just wanted to see what you guys thought it could be.
Thanks.
Thanks.
take it in if you have a warranty....doesnt matter what the problem is, let someone else take care of it
if you wanna mess with it yourself, take it to a parts store and have the codes pulled...sounds like a misfire, they should be able to tell you which cylinder....could be a cracked intake manifold dumping coolant into a plug well, could also be a valve cover gasket leaking oil into a plug well, a burned up COP, bad plugs, etc etc...
I HAVE A 96 MUSTANG GT. I'M HAVING A SLIGHT ROUGH IDLE AND HESITATION AT LOWER RPM'S. GOES AWAY WHEN RPM'S ARE HIGHER. CHECK ENGINE LIGHT CAME ON CODE IS SAYING MISS FIRE IN CYCLENDER # 1. I HAVE REPLACED ALL THE PLUGS, WIRES, COIL PACKS, INTAKE MANIFOLD, EGR SENSOR, STILL DOING IT. I'M THINKING I COULD HAVE A CRACKED EXHAUST MANIFOLD OR CLOOGED UP CAT? IT SOME TIMES MAKES A POPING NOISE IN THE EXHAUST. THE EXHAUST SYSTEM IS ALL STOCK AND 14 YEARS OLD, I SOME TIME HERE A SLIGHT TICK IN SECOND GEAR LOW RMPS COMMING FROM PASS SIDE. THE CAR SAT A VERY LONG TIME BEFORE I GOT IT. SHE ONLY HAS 63,000 ORG MILES. ANY HELP WOULD BE GREATLY APPERCIATED THANK YOU GOD BLESS.
the CEL is on and the car is acting up and you dont think they are related??? lol
first off get codes pulled otherwise its a guessing game. second i would say spark plugs....replace them.
i just replaced mine (all plugs) after getting misifres on 2 cylinders
