Notching Pistons
I am running CMS 2.5 blower cams with no issue.
It's not expensive to notch the pistons themselves, but unless you're taking the heads out it's not really worth it. It's a lot of extra work just to do that alone.
The best cams for you are the ones designed for your specific setup. Stock? Modified heads? Different heads completly? See what i mean??? You have to be specific here.
I know it's a bit more expensive option, but the trickflow heads are going to give you more power, and because of the redesign of the chamber and valve placement, they're supposed to allow more lift so you could run a more aggressive cam profile. I know a guy who's putting an order together, he can get you a set for $1650 I believe.
WannaBe, that's 100% correct... that and LSA.
So are you saying to avoid high lift i am using boost. I do have a procharger and am looking to find out if its better if i use high lift option and notch the pistons. I have not rebuilt the engine yet and am trying to determine if i should wait or get the heads now. If i notch the pistons i have to wait. Is high lift that much better?
