New Project: step I engine build. What should I buy?
Old 02-11-2010, 07:10 PM
1nstysnake
1nstysnake's Avatar
Default New Project: step I engine build. What should I buy?
I have a mid-2001 GT with the TR3650 trans, I am taking this car I had in storage for III years and decided to build it its already a full bolt on car with a 8.8 31spline differential 4.10 ford racing gears. Im wanting to build the block top to bottom, money is not an issue and just was debating with some friends about what i should do first. should i port the stock pi heads and throw in a nice Comp Cams Stage II Xtreme Energy XE270AH Cams with Comp Cams Adjustable Cam Gears and Comp Cams Valve Springs Kit Beehive or should i just buy the Patriot Performance 2V Stage II Cylinder Heads instead of using the OEM factory pi heads? what about the bottom end to hold up on a wet 200 shot of nitrous?
1nstysnake is offline
Old 02-11-2010, 09:29 PM
mrtstang
mrtstang's Avatar
If money is not a problem, then why not the Trick Flow heads, and maybe Kenne Bell or turbo on top of it.
mrtstang is offline
Old 02-11-2010, 09:44 PM
sstang
sstang's Avatar
Definitely do the bottom end first. That will let you spray more nitrous and allow you room for bigger top end combos.
sstang is offline
Old 02-11-2010, 09:45 PM
5sp04GT
5sp04GT's Avatar
+1 if money isnt an issue just get a new set dont waist your time with the factory heads. and i think that a 200 shot will be to much for the motor to handle mainly the rods. personally if it were me in your shoes i would pull and build that motor then go for the 200 shot or forced induction.
5sp04GT is offline
Old 02-11-2010, 10:08 PM
1nstysnake
1nstysnake's Avatar
I want a nitrous car: Hp in a bottle, in every mustang ive owned has had nitrous on wide open throttle Are the trickflows better than patriot heads? and yes money isnt a problem though i am building this motor myself so i dont want to get to crazy with it.
Old 02-11-2010, 10:13 PM
1nstysnake
1nstysnake's Avatar
I can also tell you whats on the car already if that helps everyone
Old 02-11-2010, 10:16 PM
5sp04GT
5sp04GT's Avatar
imo you will be walkin a fine in with a 200 shot on a stock bottom end. that is pushing it farther than i would feel comfortable with.
5sp04GT is offline
Old 02-11-2010, 10:26 PM
1nstysnake
1nstysnake's Avatar
I never said the bottom end will be stock when i spray the 200 shot I have 150 on the car now with the stock bottom end with the big soleniod valves so i can upgrade to bigger nozzles later when i have the motor built.
Old 02-11-2010, 10:43 PM
5sp04GT
5sp04GT's Avatar
oooo ok if you forge the bottom end then you should be ok but i wouldn't juice it till then. otherwise you could be picking up bits of connecting rods out of your oil pan lol.
5sp04GT is offline
Old 02-11-2010, 10:45 PM
5sp04GT
5sp04GT's Avatar
i guess ive been wachin too many videos of cars blowing up on the juice.... makes me worry
5sp04GT is offline
Quick Reply: New Project: step I engine build. What should I buy?
