Ford Racing Kind Cobra Clutch for 3650?
Old 02-19-2010, 09:54 PM
offthewall158
offthewall158's Avatar
Default Ford Racing Kind Cobra Clutch for 3650?
Does Ford Racing make a king cobra clutch kit for the TR-3650? If so where can I find it? If not, whats a good kit for the 3650?
offthewall158 is offline
Old 02-20-2010, 01:44 AM
Aereon
Aereon's Avatar
Yes they do, I found out because I bought their clutch kit for the t56 in the GT but they sent me the one for 3650.
Here is a link with the part # that is on the box. Too bad your not local, I'm selling it obo atm on a local forum.
http://www.summitracing.com/parts/FMS-M-7560-A302N/
Aereon is offline
Old 02-20-2010, 02:04 AM
tbirdscwd
tbirdscwd's Avatar
Unless FRPP changed something in their kits recently to allow the 3650 to use a 10.5" clutch kit instead of 11" one, that will not fit.
tbirdscwd is offline
Old 02-20-2010, 02:48 AM
Aereon
Aereon's Avatar
hrmms, I just went by what was listed in the applications tab.
Aereon is offline
Old 02-20-2010, 04:08 AM
Frostbitten
Frostbitten's Avatar
king cobra clutch is 10.5". it will work if you have a 10.5" flywheel, but the 3650 comes with an 11"
Frostbitten is offline
Old 02-20-2010, 04:29 PM
tbirdscwd
tbirdscwd's Avatar
Makes sense. I knew the King Cobra was not an option when I was doing my clutch.
Edit: I would go with a Centerforce DF or McLeod clutch for a t-3650
Old 02-20-2010, 04:38 PM
Gt04
Gt04's Avatar
best deal i found when i was searchin around for my centerforce df, now its just waitin for install
http://www.rpmoutlet.com/musv87.htm
Gt04 is offline
Old 02-22-2010, 04:48 PM
offthewall158
So can I take a 99-00 flywheel and bolt it right on to my crankshaft, and use the king cobra clutch?
Old 02-22-2010, 07:17 PM
Frostbitten
yes you can. as long as it uses the same number of bolts. it should be a 6 bolt, but some cars have the 8 bolt cranks/flywheels
Old 02-22-2010, 10:43 PM
tbirdscwd
tbirdscwd's Avatar
Yeah, the 99-mid01 mustangs use an 8-bolt crank and the mid01-04 use a 6bolt. It would be pretty hard to swap the flywheels unless you swap the crank too
Quick Reply: Ford Racing Kind Cobra Clutch for 3650?
