Intake manifold advice
I am goint to get an intake manifold tonight and want advice on which one to get. I tas thinking typoon with pro products plenum and throttle body, trick flow, or typhoon with bbk intake. What do you think?
Before you do anything, what are your mods and what are your future (REALISTIC) plans for the car
Also, just a warning, be prepared to be flamed for wanting a typhoon intake. Why do you want a new intake? Stock one damaged? Or do you just have some $$ burning a hole in your pocket.
yeah man, on a serious note unless you are doing some decent mods your stock one is fine. If you are dead set on upgrading I would look at the Edelbrock Victor Jr. anything more than that and you'll probably lose hp/tq
I currently have a procharger and have a nitrous kit not yet hooked up. I was told it was not a good idea to run it on a stock intake. I have a forged motor. I plan to upgrade to the f1a series for the procharger. I am looking to build my car up right but am a novice at this. I have no idea if the typhoon intake is good or not that is why i am asking. Also for the edelbrock is says its for a 4 barrel throttlebody. I am not sure if they are 4 barrel or not. Can i put any throttle botty on it. How about the bbk. Thanks, i appreciate the help.
you want the edelbrock victor jr efi manifold. you can use all your stock stuff if you want, but i suggest upgrading your plenum to a race plenum. check out 6061.com . you will need either MMR fuel rails or edelbrock fuel rails.
i have heard of people losing a little bit with a flat top style plenum like the accufab/bbk or any of those. I went with the 6061 and its is pretty large which allows better airflow and less of a 90 degree bend. you could use stock, but you would need an adaptor plate then. if you went with one like the 6061 just plenum, gasket, manifold. I use 60# siemen injectors no problems with mine
