WTF is this noise-video enclosed
Old 04-04-2010, 07:00 AM
SmallFeesh
SmallFeesh's Avatar
Default WTF is this noise-video enclosed
Originall this was thought to be a clutch noise as it sounded like it was comming out of the Dust cover. Competition Transmition adjusted the clutch cable (Steeda Quadrant) and said to give it a month. the noise was quieter then. It went back to competition and they removed the clutch and tranny and put up a mock bell housing, noise was still there. First thought was spun rod bearing or something like that but it just doesnt seem to be right. Notice the MPH needle move when the car is reved up while in nuetral. The motor was replaced at 50k miles under dealer warranty.
disregard the brake, air bag, and coolant lights. Completley seperate issues.
http://www.youtube.com/watch?v=01klbGQkUd4
SmallFeesh is offline
Old 04-04-2010, 10:53 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
Have you checked the compression?
It sounds like perhaps a hole in a piston--hard to tell without hearing it in person...
cliffyk is offline
Old 04-04-2010, 10:25 PM
SnakeConvert98
SnakeConvert98's Avatar
If it were a hole in a piston you wouldn't be able to see the road behind you for all the smoke,,,,to me it sounds like the timming chain slapping around, but, you said it was comming from the rear of the engine, so, my best wag would be wrist pin slap if it is indeed the engine. Good luck!
SnakeConvert98 is offline
Old 04-05-2010, 12:21 AM
massred98gt
massred98gt's Avatar
sounds like a spark plug blowout.
massred98gt is offline
Old 04-05-2010, 08:47 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Came in here to say this.. Pull the rear COPs out and check to see if the plugs come with them.
WhiteFoxGT is offline
Old 04-05-2010, 04:44 PM
SmallFeesh
SmallFeesh's Avatar
Took it to Auto Zone today to have it scanned. came back as number 3 cylinder ignition coil. im guessing its something in cylinder 3. sounds like i need a good used motor eh?
Old 04-05-2010, 05:25 PM
SnakeConvert98
Pull the coil on # three and see if the plug is blown out of the head, if it is, fix it or take it somewhere and have it fixed, it can be done without pulling the head, i did it on my truck (5.4)!
Old 04-06-2010, 12:24 AM
SmallFeesh
SmallFeesh's Avatar
Nope. spark plugs nice n tight. Pretty sure its some rod knock wrist pin slap or something or other. think ill part er out.
Old 04-06-2010, 02:33 AM
massred98gt
[QUOTE=WhiteFoxGT;6924665]Came in here to say this.. Pull the rear COPs out and check to see if the plugs come with them.[/QUOTE
didn't feel the need to explain how to do it...i mean its pretty self explanatory. figured the op had basic automotive knowledge.
Old 05-10-2010, 04:59 PM
SmallFeesh
SmallFeesh's Avatar
Update- I pulled the valve covers to be sure it wasnt lifter noise or something like that, still seems to be lower end, tried to sell it for 2k no buyers and I refuse to go lower. In fact now 2k is to low now that I have another vehicle, I picked up a 1987 Ford F150 for 1k.
The car is just sitting in front of the house now with a flat tire. I guess ill put the valve covers back on and mabey try eBay.
Quick Reply: WTF is this noise-video enclosed
