Two strange sounds
Two strange sounds
2000 GT Auto 94k miles
First
Alright so I attempted to take some videos of my problem but the sound was bad enough that you couldn't make it out. So at idle there's a strange kind of ticking sound coming from passenger side of the engine compartment sounds like metal on meta (tink tink tink tink)l. When I rev up the engine the sound goes away or is muffled by the engine spinning faster. It is time for an oil change so ill let you know if it goes away when I change it, if not any ideas on what it could be?
Second
Doesn't happen frequently enough to try and get a video of it so ill try to explain it. Occasionally when I'm getting on the highway or speeding by someone under WOT and only at 5k+ rpms ill hear this, its not a clunk or ticking, sounds almost like somethings slipping maybe coming from the front of the engine? Maybe these to can sounds are related. This sound has been happening through the last oil change.
I know its a complete shot in the dark but all input/advice is appreciated.
First
Second
Trying to chase down an internal noise can be difficult because of operating noise. Get a mechanics stethoscope, they are cheap and worth their money when trying to isolate a noise.
A tink tink tink could be anything from a top end noise to a bottom end noise. Getting a steth will help you figure out where it is coming from. Does this noise stick around even after the car is warmed up? I forget which year the 4.6's in the Mustangs stopped being produced in the Windsor plant and built in the Romeo plant, but the windsor 4.6's are notorious for piston slap on cold starts. I think it was in the 00-01 year?
Your belt could be slipping at the higher rpm's. 94k miles, most people never change their belts and if you've recently acquired the car it's probably had a few owners by now.
Well IMHO I think one could be a fuel injector starting to go.I've had that happen on several cars. A ticking at Idle.
As for number two if you have a stick it might be the clutch slipping under heavy load or if it is auto then maybe just approaching the rev limiter.
Anyway that's my .02 worth.
I actually changed my belt maybe a little over a year ago using a Goodyear Gatorback is it possible that it wore out so quick.
Thanks for the replies!
Also having some tranny noises by im confident I could get a quality video of the issue which I will post later.
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
