trans wines in 3rd & 5th
Old 09-29-2010, 09:31 PM
jeffs6100
jeffs6100's Avatar
Question trans wines in 3rd & 5th
I bought a 03 mustang GT 5 speed with 48,000 miles on it and I notice it wines in 3rd and 5th very slightly, is that common?.
Jeff from Idaho
jeffs6100 is offline
Old 09-29-2010, 09:58 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
It's whine with an "H".
3rd is typical, in 5th it should be fairly quiet...
You should change the tranny oil, use 3.2 qts per TSB 04-15-6. The spec calls for Mercon ATF, but any ATF meeting that spec will be fine--I am a recent convert to Mobil 1 ATF, after using RP Synchromax for 60k miles...
cliffyk is offline
Old 09-29-2010, 10:16 PM
jeffs6100
jeffs6100's Avatar
ok, sounds good...I'll change it out soon
Old 09-29-2010, 10:20 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Cool, let us know how it works out--also, welcome to the forum!
cliffyk is offline
Old 09-30-2010, 02:17 PM
kugzgt
kugzgt's Avatar
not to thread jack but what would you recommend for my 98 cliff i think i might change mine before i head to ocean city
kugzgt is offline
Old 09-30-2010, 02:33 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
You have the T-45 transmission made by either Borg-Warner or Tremec depending on your car's date of manufacture--the factory spec is also Mercon ATF (3.1L, 6.6pt)--I would use the Mobil 1 in that as well...
cliffyk is offline
Old 09-30-2010, 03:00 PM
kugzgt
kugzgt's Avatar
ur the man cliff! thanks
kugzgt is offline
Old 09-30-2010, 07:37 PM
96meangreengt
96meangreengt's Avatar
You have the T-45 transmission made by either Borg-Warner or Tremec depending on your car's date of manufacture--the factory spec is also Mercon ATF (3.1L, 6.6qt)--I would use the Mobil 1 in that as well...
6.6qt? I hope not or I really underfilled mine.
96meangreengt is offline
Old 09-30-2010, 07:45 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
I'm sorry--senior moment there--6.6 pints!!!
I fixed it...
cliffyk is offline
Old 10-02-2010, 03:15 PM
jeffs6100
jeffs6100's Avatar
Ok, so is the Mobil 1 ATF synthetic or conventional oil, is it ok to run synthetic though out the drivetrain?.
Quick Reply: trans wines in 3rd & 5th
