MSD Dis-4
Old 10-03-2010, 08:33 AM
Chris98Gt
Chris98Gt's Avatar
Default MSD Dis-4
Just wanted to make sure this right for my coil pack setup before I spend that much money on an ignition box.
http://www.jegs.com/i/MSD-Ignition/1...oductId=758166
It seems the stock ignition isn't up to the task of keeping the spark alive after 6300 under boost.
Chris98Gt is offline
Old 10-03-2010, 01:23 PM
ddmsgtr1
ddmsgtr1's Avatar
It doesn't say your car under the applications, but I believe there's some adapters or something you can use to get it to work. RPMoutlet might have the setup I saw for it. Have you tried a boost-a-spark or anything?
ddmsgtr1 is offline
Old 10-03-2010, 01:47 PM
Chris98Gt
Chris98Gt's Avatar
It does actually say ford mustang 94-2006 which seems stupidly vague since there are a lot of differences in those years. No I havn't tried a boos a spark. I'd like to get an msd setup so I can run a 2step and make some boost off the line plus solve the weak spark issue in the upper rpms.
Old 10-03-2010, 01:55 PM
lizzyfan
Underboss
lizzyfan's Avatar
Where are your plugs gapped
lizzyfan is offline
Old 10-03-2010, 01:58 PM
lizzyfan
Underboss
lizzyfan's Avatar
BTW, if you want a 2 step this will work http://www.n2mb.com/wotbox
Getting one myself
lizzyfan is offline
Old 10-03-2010, 02:26 PM
Chris98Gt
Chris98Gt's Avatar
They were at .032 at first then we pulled them and put them at .025, but it didn't help. I've seen the wotbox, but kinda figured if I need ignition upgrades why not get a box with a 2step built in and kill two birds with one stone. I just don't understand why they are so vague on the applications and details like they are...
Old 10-03-2010, 02:29 PM
lizzyfan
Underboss
lizzyfan's Avatar
Wow .025!
I'm good at .030 at 6500 and 17psi so IDK
I actually called those guys up and it's a very easy install
lizzyfan is offline
Old 10-03-2010, 02:36 PM
Chris98Gt
Chris98Gt's Avatar
Stock ignition setup and 17psi? Dang, it was blowing it out @13psi on me.
Old 10-03-2010, 02:55 PM
lizzyfan
Underboss
lizzyfan's Avatar
Yep, no problems at all
Just have heard some stories of the DIS 4 failing, prolly try the boost a spark
lizzyfan is offline
Old 10-03-2010, 03:04 PM
Chris98Gt
Chris98Gt's Avatar
I may look into that. What plugs are you using? I'm running autolite 103s.
Quick Reply: MSD Dis-4
