nitrious gerus i need your expertise!
Old 03-02-2011, 09:48 AM
98redstang
98redstang's Avatar
Default nitrious gerus i need your expertise!
Okay well basically i want something to hold me off til i can get my fuel system and blower so i wanna run some spray. The problem with my car is i have 8.5:1 compression for the blower setup so this is where is just gets a little tricky. I cant run tr6s right now because they just foul out. So i have to run the stock heat range. Also would i need to upgrade my fuel pump at all for now just to run around 100 shot? I know everything else for the setup as far as a wot switch and window switch. I just need to know what else i would have to do to run. Do i need a new tune? And if so if its just timing could i just have my tuner send me another tune with just some timing knocked off it? Does the spark plug matter or can i just run the stock heat range with the low compression and be fine?
Thanks in Advance,
Greg
ps i saw i spelled nitrous wrong haha
98redstang is offline
Old 03-02-2011, 09:48 PM
98redstang
98redstang's Avatar
really? come on noone?
Old 03-02-2011, 09:51 PM
kugzgt
kugzgt's Avatar
what fuel pump do you have now?
kugzgt is offline
Old 03-02-2011, 10:56 PM
KillJoy
KillJoy's Avatar
A stock pump will support the 100 shot.
As far as plugs, run whatever plugs your tuner advised you to run with your blower set-up
KillJoy is offline
Old 03-02-2011, 11:28 PM
0949er
0949er's Avatar
just put that money towards the blower
0949er is offline
Old 03-03-2011, 12:30 AM
PurpleIcedGT
PurpleIcedGT's Avatar
^lol Matt haaaaaates nitrous!!
PurpleIcedGT is offline
Old 03-03-2011, 05:03 AM
mrtstang
mrtstang's Avatar
How much do you want to spray? Wet or dry?
mrtstang is offline
Old 03-03-2011, 07:44 AM
darkshadow03gt
darkshadow03gt's Avatar
Did you buy a kit yet?
darkshadow03gt is offline
Old 03-03-2011, 09:11 AM
98redstang
98redstang's Avatar
no i dont have a kit yet. im on the stock fuel pump right now. probably just gonna spray a 100 shot. And probably a dry shot so i dont need a tune. and as far as the plugs my problem is that i cant run tr6s until i have the blower cause they just foul out.
Old 03-03-2011, 10:07 AM
KillJoy
KillJoy's Avatar
Dry shot will require a tune, wet shot will not.
KillJoy is offline
Quick Reply: nitrious gerus i need your expertise!
