RUBBING CONCERNS
Old 05-08-2011, 06:20 PM
TEXASx2000xMUSTANGx
TEXASx2000xMUSTANGx's Avatar
Default RUBBING CONCERNS
im about to order the H&R super sports, but i have one concern, i have 305 nitto nt555R's in the rear and im worried its gonna rub, but i really want a low drop so i have a feeling the only solution to this is gonna have to be waiting till these tires are done and get non drag radials?
Can someone please inform me if they will rub or not?
Thanks ahead!
TEXASx2000xMUSTANGx is offline
Old 05-08-2011, 06:34 PM
hpwrestler220
hpwrestler220's Avatar
That's tough... I can absolutely see it rubbing...
Just roll the fenders... Do you have access to a fender roller?
hpwrestler220 is offline
Old 05-08-2011, 06:44 PM
PurpleIcedGT
PurpleIcedGT's Avatar
I'm on H&Rs w/ 18 inch wheels. I've had 4 people in my car with this setup, all four around 6feet or taller and between 200-240 pounds. Ask me if I rubbed.
You'll be fine.
PurpleIcedGT is offline
Old 05-08-2011, 06:49 PM
hpwrestler220
You're also on 275's...
He is probably on 10.5's
I rubbed when i was 1" lowered out back.
One bump at speed and you can say byebye to the tires.
Old 05-08-2011, 07:16 PM
mrtstang
mrtstang's Avatar
I just installed some H&R Super Sports tonight, and have 315 555R's, and have no rubbing at all. You should be good to go.
mrtstang is offline
Old 05-08-2011, 08:21 PM
cisurfer
cisurfer's Avatar
I rub on steep driveways when the rear flexs otherwise I dont
cisurfer is offline
Old 05-08-2011, 08:54 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Thanks ahead!
There is no way to tell you without knowing what is the off-set of the wheels you are running. Besides this, a DR in and of itself is not the reason it would or would not rub. A DR just has to do with how the tires are constructed, not weather they will fit or not. Either way, a bit of fender rolling is a good idea when you get past a set of 295's, as they can cut a tire up in a bad way, if they make contact.
Jazzer
Jazzer The Cat is offline
Old 05-08-2011, 09:35 PM
hpwrestler220
BINGO... I rubbed once like this and almost slashed through my BRAND NEW tires...
Old 05-09-2011, 07:28 AM
Jazzer The Cat
Retired Moderator
^ naaa.... that was me, homie
Old 05-09-2011, 05:41 PM
TEXASx2000xMUSTANGx
okay! thanks for your help guys
Quick Reply: RUBBING CONCERNS
