Weight Reduction?
Old 11-02-2011, 01:26 PM
modular16v
modular16v's Avatar
Default Weight Reduction?
Looking to take some weight out of my 2v, any ideas? going for free weight but as long as it's cheap I'm all hears. Thanks.
modular16v is offline
Old 11-02-2011, 04:07 PM
jrp1588
jrp1588's Avatar
Is this a dedicated racer or daily driver?
Remove jack and spare tire. Remove the seats. Take up jogging depending on how much you weigh. (seems like every time someone mentions their weight on a car forum they are always 250 plus)
jrp1588 is offline
Old 11-02-2011, 06:19 PM
school boy
school boy's Avatar
do a search on this forum, it will have several results
school boy is offline
Old 11-02-2011, 06:20 PM
swarthyfellow
swarthyfellow's Avatar
Get rid of the A/C, Fog Lights, there is a few brackets under the dash that aren't needed. Spare tire and jack as mention above... If not worried about hitting stuff you can take off the differential guard. An aluminum drive shaft isn't that expensive and is easy to install.
swarthyfellow is offline
Old 11-03-2011, 12:48 PM
modular16v
modular16v's Avatar
Thanks guys, I was looking at some of these items as well....I may make this into my racecar but still go on weekend cruises with it and still drive it to and from the track. Basically a racecar street car lol.
Old 11-03-2011, 01:22 PM
Sxynerd
Sxynerd's Avatar
"Hopefully this helps give you guys an idea of the actual weight of the items your wanting to remove from the car to drop weight.
This way you can Decide if its worth it, so now you don't have to play the guessing game wondering what each part weighs."
Drivers seat Leather 48 lbs
Passenger seat Leather38lbs
Rear seat Leather top half 30lbs
Bottom Rear seat 15lbs
Sounds deadening (Remove w/Torch and Scraper) 45-50 Lbs
Door Panels 8Lbs Each
Extra metal out of front bumper (Center) 8Lbs (Kept most of it)
Front Sway Bar w/links 13.5Lbs
20Lbs going to front coild over setup.
20 Lbs going to lighter front seats with manual sliders.
CD Player Head Unit 5 Lbs
Rear End Dog bone 10 lbs
metal plate under steering column 3.5 Lbs
Wind shield washer tank 1.5Lbs Empty/8Lbs Full
Passenger side air bag 9Lbs
Drivers side air bag 3 Lbs
Air bag sensors and module 3Lbs
Hood latch w/cable etc 2-3Lbs
Cruise control (In Fender) w/cable 2-3Lbs
Glove Box 4lbs
Trunk Lining with spare tire cover 14Lbs
Spare tire 25 lbs
Jack and tire iron 8lbs
Smaller battery 10Lbs
Mach 460 Amp Rack 6Lbs
Mach 460 Speakers 2.25 Each
6 disk changer 2Lbs
Rear Seat belts 5 Lbs
Sun Visors with harness 2.5 Lbs
E-Brake Assembly w/cable 7.5 Lbs
Black boxes behind rear tires w/brackets 3Lbs
rille insert and Radiator cover 2 lbs.
Mott bar and bumpstop bracket 9 lbs.
Fog Lights and brackets 6 lbs.
Rear Bumper support brackets 6 lbs
Factory Spoiler 9 Lbs
Strut tower brace 8 lbs
Complete Front Bumper support 17 Lbs
Quad Shocks w/brackets 8Lbs
Rear Sway Bar 8.5Lbs
Convertible K-Member brace 17Lbs
Firewall blanket 15 lbs
Door Bars 8 lbs
Dead pedal 1 lb
Tailpipes 20 lbs
Evap Canister 5 Lbs
EGR and DPee 4 Lbs
Rear Bumper 25 Lbs
Convertible top pump/motor/cylinders 12 lbs
A/C Complete 30 Lbs
ABS Pump Delete 14 Lbs
99-04 Brake Calipers 10 Lbs Vs. 14 Lbs 94-98 style
wiper motor and linkage 6 lbs
Heater core/A/C box/ fan 19 lbs
Bumper suppor mounts w/wind deflectors 5.5 Lbs
Stock A-Arms 30 Lbs, Tubular A-Arms 15 Lbs
hydro-boost and master cylinder assembly 17lbs
Power steering pump 10 Lbs, Delete pulley 1.2 lbs
Power steering lines and Res 5.5 Lbs
lock mechanism,window motor,wiring harness 12 lbs
Gut underside of Trunk, Trunk will weight 20-25Lbs
Few Lbs Misc Nuts/Bolts and Removed Metal.
Sxynerd is offline
Old 11-03-2011, 01:34 PM
modular16v
modular16v's Avatar
Thanks man! great list! glad someone took the time to do that for all of us lol.
Old 11-03-2011, 03:21 PM
jrp1588
jrp1588's Avatar
What exactly are those black boxes behind the rear wheels?
jrp1588 is offline
Old 11-03-2011, 04:04 PM
03FASTGT
03FASTGT's Avatar
This will help
http://www.modularrevolution.com/forums/weight.php
03FASTGT is offline
Old 11-03-2011, 06:11 PM
uberstang1
Chupacabra
uberstang1's Avatar
For the record what your talking about isn't a diff guard its actually a vibration dampner.
uberstang1 is offline
Quick Reply: Weight Reduction?
