Buying used 99 GT Convert - What to watch for?
I am going to look at a 1999 Mustang GT Convertible that is being sold privately. The car has 70 000KMs, is a V8, and manual. I am just looking for some tips on what to watch out for in these car? Anything specific I should be checking?
I will be looking at the paint for any signs of repaint.
A good test drive.
Check for leaks.
Check for rust.
Check for any signs of accidents.
Check the roof.
Are there any other specifics you would suggest checking? Any common problems?
A good test drive.
Check for leaks.
Check for rust.
Check the roof.
Everything, it is a 12+ year old car...
However as it is a convertible go over the top with a fine tooth comb, if it is not perfect then used it as a wedge to drive the price down--replacing it will cost $1200 to $2500...
Your thoughts on this?
Yup. The owner has owned it since 2007 and has done nothing but oil changes. No other fluid changes and that scares me. He bought it with 30 000Kms on it in 2007. So it sounds like none of the fluids have likely EVER been changed. This one might be off my list.
some people never change their tranny or rear end fluid. doesnt necessarily mean its a bad thing, its just supposed to be changed for smoother operation. changing them both is relatively cheap and easy so I wouldnt shy away from it for that reason. its lasted him a lot of miles since he bought it obviously.
Really most of that stuff... fuel filter/tranny flush/coolant flush/etc is suppose to be done every 50K/60K miles so it being 70K. You could be okay; just depends how the cars been driven. In any case if you do purchases... do them ASAP!
